Salta al contenuto principale
Any small, single-cylinder carbureted gasoline engine, usually used for lawnmowers. The engine used to create these guides is a Briggs and Stratton 300e series engine.
My Craftsman ys 4500 20 hp cranks but wont start even with start fluid
I accidentally ran over a chunk of wood and the mower shut down so I figured I sheared the flywheel key and replaced it and the spark plug with no luck I also sprayed starting fluid into the air filter after taking the filter out and nothing happened it just cranks over very fast but won’t start PLEASE HELP !!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta più utile
Lou C This “I also sprayed starting fluid into the air filter” points to your mower not having a spark. Check on that first. If so, you do want to let us know what the exact make and model number for your mowers engine is.
Punteggio 1
Aggiungi la tua risposta
Lou C sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 3
Ultimi 30 giorni: 27
Tutti i Tempi: 447
