Salta al contenuto principale
A personal computer that resides in one location with its core components inside a case separate to third-party peripherals required for operation, such as a mouse, keyboard, and monitor.
542 Domande Visualizza tutte
My Pc power on but no display
Hello, I build a pc with this main specs :
Amd Ryzen 3 1200
Motherboard Gigabyte A320M-S2H
Ram Corsair Vengeance LPX 8GB DDR4-2400MHz (CMK8GX4M1A2400C16)
But when I assemble everything, the pc seems to work but there was no image on the screen. Then I add a GPU on the pc and the image was ok from the GPU. After 3 days I opened the PC and I have seen a blue screen and it was memory management. I run the memory diagnostics windows have and it says hardware problem found. Can anyone guess of the problem?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
let us know what you mean by this “Then I add a GPU on the pc “.I assume you are referring to a video card. Also, just to clarify it sounds like all you are getting is a blue screen? I would suggest to start with a different video card. That way you can at least rule yours out.
Update (06/03/2019)
Savvas Giannoukas yes, if you can actually read text etc. on your screen and get error messages then it is not your graphics card. Apparently this error can be caused by software or hardware conflict
virus infection
faulty video driver
faulty memory
disk errors
If you can still access Windows (I assume you are running Windows?) then try to invoke the Run command, type mdsched.exe and hit Enter.
If nothing else then try and check on here for more solutions.
Punteggio 1
4 Commenti:
Graphics Card sorry, I was writing this in hurry. I get blue screen with an error of memory management and I read in some forum that it might be faulty RAM
da
Unfortunately, when it shows me the sign in page of windows then it appears the blue screen. I tried 3 different HDD but nothing so I assume is RAM problem but I don’t know
da
If the memory is being run in D.O.C.P mode in BIOS try running it in normal mode as sometimes overclocked memory can cause the system to be unstable. You can access bios via pressing the DEL key on keyboard when you see the BIOS splash screen on the monitor.
da
It’s not overclocked... I ordered a new ram to test out. When I have results I will inform you
da
Aggiungi la tua risposta
Savvas Giannoukas sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 785
