Salta al contenuto principale
Repair guides and support for C/K pickup trucks sold by General Motors under the GMC brand, including the GMC Sierra.
77 Domande Visualizza tutte
crank and rod bearings torque sequences
on a v6 1993What is the crank and rod bearings torque sequences
Questa è una buona domanda?
Punteggio 0
1 Commento
@gudstuff what displacement is this engine? 4.3?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
@gudstuff this is where it gets interesting:
Tighten
11.1. Tighten the crankshaft bearing cap bolts on the first pass to 20 N•m (15 lb ft).
11.2. Tighten the crankshaft bearing cap bolts on the final pass an additional 73 degrees using the J 36660.
Install the connecting rod caps, bearings and nuts.
Tighten
7.1. Tighten the nuts evenly on the first pass to 27 N•m (20 lb ft).
7.2. Use the J 36660 in order to tighten the nuts on the final pass an additional 70 degrees.
Punteggio 1
Aggiungi la tua risposta
bronson sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 342
