Salta al contenuto principale
Guide di riparazioni, tecniche e informazioni sullo smontaggio degli smartphone Android prodotti da Xiaomi.
1695 Domande Visualizza tutte
Water damaged now my phone screen works automatically
I have redmi 5a phone . I got some water in my phone about 6 months ago but now my phone screen works automatically sometimes.when I do a screen test it shows a vertical line blinking in the lower part of the phone.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
4 Risposte
Risposta Più Utile
But ... changing the screen will not solve the liquid damages. You should clean it before changing any circuit or part.
Punteggio 2
1 Commento:
True and I think the best liquid to clean it with is with 99.9% alcohol
da
Try doing a screen replacement. If that doesn’t work, try checking for bad connections on the Logic-Board. If you found some, try replacing the logic board. Personally, I think that the Logic Board replacement will be obligatory since the one your using will probably have board-level water damage.
Punteggio 1
Change your screen display bro
While changing you could learn more about your phone... Please checkout link given below
https://youtu.be/4LCO5Ik6QzA
Punteggio 0
Redme 5a
switch on
Punteggio 0
Aggiungi la tua risposta
Sahil sharm sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 51
Tutti i Tempi: 440
