Salta al contenuto principale
I sometimes get cold air in my fridge
i have a whirlpool side by side ed5lvaxwb02 i just bought my freezer works great my fridge side doesn’t get cold enough its all most there but wont reach the highest leavel
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Cause 1
The Evaporator Coils are Frosted Over
The defrost heater assembly turns on a few times throughout the day to melt away any frost that may have accumulated on the evaporator coils. If the defrost heater assembly is defective, frost will continue to accumulate on the evaporator coils, and the coils will become plugged with frost. If the evaporator coils are frosted over, the airflow through the coils will be restricted, causing the refrigerator not to cool. Check the evaporator coils to determine if they are frosted over. If the evaporator coils are frosted over, test each component of the defrost system.
Cause 2
Evaporator Fan Motor
The evaporator fan motor draws cold air over the evaporator coils and circulates it throughout the freezer. If the evaporator fan is not working, the freezer or refrigerator will not cool adequately. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor..
Parts
Evaporator Fan Motor for your  Refrigerator
RepairClinic Item #921541
Refrigerator evaporator fan motor. The evaporator fan motor draws air over the evaporator (cooling) coils and circulates the cold air through the refrigerator and freezer compartments.
$79.77
Cause 3
Damper Control Assembly
The air damper control opens and closes to let the proper amount of cold air into the refrigerator compartment. If the damper does not open properly, it won’t let enough cold air into the refrigerator. Check the damper control to determine if it is broken or stuck closed.
Parts
Damper Control Assembly for your  Refrigerator
RepairClinic Item #1454299
Air diffuser assembly
$40.65
Punteggio 2
Have you tried adjusting the temperature, or checking the seal on the door?
Punteggio 0
1 Commento:
yes i have tried to adjusting the temp and the seal is brand new .. the air blows out kind of weak,but it feels cool coming out.i want to know how i can get colder air
da
Aggiungi la tua risposta
mike petrella sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 814
