Salta al contenuto principale
Lanciato il 4 novembre 2017. Modello A1865, A1901. Disponibile con GSM o CDMA / 64 o 256 GB / Colore Silver o Space Grey. Si pronuncia "iPhone 10".
1198 Domande Visualizza tutte
Motherboard screw holder came off causing issues
The iPhone X was working fine until the bottom right screw holder of the motherboard came off. Since then, the ear speaker, main speaker, mic isn’t working and the phone is dead slow. Can I use jump wire to remedy this? I can’t see anything connected through my bare eyes.
Please help.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Apple does have a tendency to route traces around screw holes…but not in this particular instance. That said, there are a lot of very fine traces in close proximity to the screw hole so if any one of those is compromised, then you will have issues with your logic board.
Each colour represents a different internal layer of the PCB. You will not be able to see these with your naked eye when looking “from the side”, only when looking at traces from a top perspective. I would take a closer look with a microscope to see if any the adjacent traces are visible, otherwise, you will probably not be able to repair this logic board.
Punteggio 2
Aggiungi la tua risposta
bijaya.pun sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 138
