Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Why won't 3 screws near battery go back in, after display install?
I have two a1229s and I recently swapped out a full display assembly following the manual on ifixit. Everything went fine except I can't get 3 screws back in
These 3 - http://guide-images.ifixit.net/igi/WKwoX...
(the ones under the battery, on the opposite side of the battery as the ram door; they're tilted at an angle)
First, I'm not certain which screws go back there, because i combined the screws from both mbps, and don't necessarily plan on reassembling the other one, as I'll probably just sell the parts).
I assume it's the short screw with the large head, but I tried every different type of screw and none would lock in. I feel like I could probably just manage fine without having these three screws in there, but if anyone knows how to fix this issue, or can even tell me for sure which screws should go in there (though, I made a good effort with all of them - and all 3 holes - so that's not the main issue), I would be interested and appreciative.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
LCD iPhone Screen Fix Kits
The budget option, covered by our Lifetime Warranty.
Shop Kits
Cut repair costs, not quality.
Shop Kits
1 Risposta
Risposta Più Utile
If those are the same as on a 15", they are 2.8 MM while the perimeter case screws are 3.2 mm.
Punteggio 2
Aggiungi la tua risposta
thomas cares sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 606
