Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2686 Domande Visualizza tutte
How mant times can you replace a iPhone screen before connector wear?
How mant times can i replace te screen of a iPhone before the connectors break or are weared out
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Usually this kind of connector is rated 10-50 cycles, with 25 being the most common rated cycle counts.
But that only means the connector is no longer compliant in some way, actually it still works good enough well beyond that if you handle it with care.
Punteggio 3
It depends on how gentle and precise is the hand doing the job, Some people manage to mess the connector with just one replacement by deforming the plastic part to force push it in place. If things are done properly I’d say tens of times, the 6S has pretty a solid connector.
Punteggio 2
Aggiungi la tua risposta
Lester crewe-jones sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 59
