Salta al contenuto principale
The 2018 version of the Samsung Galaxy A7 smartphone released in October 2018.
51 Domande Visualizza tutte
Power reset or unknown upload mode
Hi, i have a problem with A750SN got stuck in bootloop. After i tried to enter download mode it shows me only “Power Reset or Unknown Upload Mode”, i have tried to connect it to Z3X and click on the “Reboot to Flash” the screen says OK but in the phone screen nothing is happening.
I will write the whole text that apears in the screen of device.
[RST_START = 0x1000000 ]
ECT : PARA002n
LPDDR4 manufacturer = Samsung
LPDDR4 Process ver = D18_B
LPDDR4 Size = 4G
LOT_ID = N0000
CHIP_ID = 0753b6b4924c
[TMU] 33, 29
asv_table_version : 2
big grp : 7
little grp : 7
g3d grp : 7
mif grp : 7
int grp : 7
fsys grp : 7
cp grp : 7
Please uncheck Auto Reset option of RDX!!
And do HARDRESET by using volume down + power key 7 secounds!!
CODE MATCHED (0)
Fatal exception in interrupt
PC is at hard_reset_hook_callback+0xdc/0x120
LR is at hard_reset_hook_callback+0xdc/0x120
I have tried the “ hardreset by using volume down + power key” but it still stuck in samsung logo.
If someone has any idea how to exit this and enter the download mode i would be very thenkfull.
Questa è una buona domanda?
Punteggio 0
1 Commento
Upload mode Forced upload mode with key A10
da
Aggiungi un commento
5 Risposte
Soluzione Prescelta
The phone was water damaged and wouldn't recognize the USB cable.
Punteggio 1
1 Commento:
press power button + volum up and home button then yoU need to do factory reset data and go restart your phone and go to factory setting
and reset ur phone
da
Risposta Più Utile
after I use Z3X and click on the “Reboot to Flash” , phone will get in download mode. Then i just put the file and click on flash
Punteggio 2
My phone have problem video player out repair my phone
Punteggio 0
Ok thats stupid ur phone has water damage mine has no water damage and says the same thing i just used odin on it so thats aload dog duddy im having the same problem if someone told me what the rdx was i could do it if u google rdx and android tells about cars with android fearures
Punteggio 0
2 Commenti:
U must press power button with volum up and home button to get in android mode and do a hardware reset and clean all ur datas then go into ur settings of phone and do factory setting and reset your phone another time then it wouldn't come
da
@Buisan Kahbo I've try to press power button and volum up button only cause my phone doesn't have home button, but it's still doesn't work. What should I do?
da
حالت آپلود اجباری حالت آپلود با کلید A10 The second SIM card does not work either
Punteggio 0
Aggiungi la tua risposta
Adrian Zymeri sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 83
Tutti i Tempi: 14,153
