Cut electrical wire cord for A1243
I need to know how to replace the cable or repair it.
Questa è una buona domanda?
If it is an USB cable that was cut then you should open your keyboard and re-solder a new cable to the PCB. Please mind to properly connect polarity of the USB power supply and Data cables. It will be 4 wires + ground so if you are handy with soldering iron then you should handle with it.
then finish your %#*@ teardown and fix it while your doing it
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 27
Tutti i Tempi: 1,181
