Early 2009 Display Assembly on Mid 2009 system
Hi,
I was wondering if the display assembly from a late 2008 to early 2009 would fit on my Mid 2009 MacBook Pro 15” 5.4.
The connectors seem to be identical.
Thanks for your help :-)
Questa è una buona domanda?
4 Commenti
Your systems specs: 13" MacBook Pro 2.53 GHz Core 2 Duo (with SD slot)
da Dan
Are you up to replacing the LCD panel alone? Or do you need to replace the full display assembly (case damage).
da Dan
I was planning to replace the full assembly. I don't have the tools to remove the glass, so buying a used assembly is the cheaper choice.
da Arne Büsing
Then you'll need the correct assembly part as there is enough differences in the part to prevent the substitution of the full assembly.
da Dan
