Salta al contenuto principale
Dancing water speakers are computer speakers that feature jets of water illuminated by bright multi-color LED lights.
Speakers are screaming. PLEASE HELP
Water is shooting up np and the lights work but there is a sound like a scream whenever it happens. tried turning down and even at a low volume it still screams when the water shoots up. I really like these speakers and use them for gaming and I dont want to have to replace them. Please help
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Risposta Più Utile
Sounds like either the water pump (more likely) and/or the pressure fan (less likely) is shot. Here's a good video that explains how these work:
https://www.youtube.com/watch?v=vfU6iV-R...
I would go with a dying pump motor. Take it apart, find the part number, locate it online, and replace.
Punteggio 1
1 Commento:
ty so much I will give it a shot
da
It’s probably you’re playing it at a low volume that’s why same here as I got watt speakers to when I full blast it it’s fine but when the volumes low it makes weird noises
Punteggio 0
Just sorted this exact issue , its the grease around the motor spindle runing dry ! , take apart apply lithium grease and or WD40 to the spindle , then test to work the grease into the motor ...
Punteggio 0
Aggiungi la tua risposta
mamac253 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,776
