Salta al contenuto principale
Why my laptop not powering / turning on when plugged in?
Before this problem happens, my laptop gives an indication three weeks back that the battery life is already low and there was an option to extend battery life which I selected. The laptop was working fine. Yesterday while I tried working on my laptop, it was on the standby mood then I hit the enter key to turn back the screen so i can log in then i was able to do so. After a few hours working, suddenly it hangs up and tried pressing all the possible keys but the cursor not moving so I turn it off using the power on/ off button as i could not shut it down since the cursor is not moving (this is which I always normally do whenever my laptop hangs up, then power it on again). But this time when i did the same way and tried to power it on, it does not turn on. I connect the power plugged in but the power light indicator lights for a second then went off. I press the power button on/off but nothing is happening. Kindly tell me what should I do?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
Batterie per PC portatili
Una soluzione semplice per un grande aumento di potenza.
Acquista ora
Acquista ora
1 Risposta
First remove the battery and remove the charger. Press and hold the power button for 30 seconds. Next put the battery back in and plug it in, see if the light comes on. Press the power button to turn it on. If it still does not turn on, repeat the above steps but do not put the battery back in just plug it in and try to power it on. If this does not resolve the issue then you may need to replace the power jack.
Punteggio 0
Aggiungi la tua risposta
Fed sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 22
