Salta al contenuto principale
Rilasciato il 16 settembre 2016. Modello 1660, 1778. Disponibile come GSM o CDMA / 32, 128 o 256 GB / Rose gold, gold, silver, black e jet black.
2264 Domande Visualizza tutte
I dropped my iPhone 7 and both cameras and flashlight stopped working
I dropped my iPhone and suddenly the both cameras (rear and frontal) and the flashlight stopped working. What it could be? Does it have a fix or its better to replace the phone with a new one?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
The rear camera is the key here. The front camera and flash will not work if the rear camera is damaged and cannot be enabled. So the simple thing to try is replacing the rear camera with a known-good replacement part (or from a quality vendor) to see if that solves your problem. If it doesn’t, then you may gave a logic board issue. Repairing a camera issue at the board level is relatively straightforward and much less expensive than replacing the device.
Punteggio 3
1 Commento:
Thanks! I'll try this one
da
It’s probably a board level repair. You could try and replace the cameras but it probably won’t do much. You could also try and do a full reset and then it might start working again.
Punteggio 1
2 Commenti:
Thank you! I'm doing a full reset right now. If it don't work, do you think i need to replace the entire logic board? Is it worth it?
da
At that rate I would just upgrade to a new phone because the iPhone 7 has so many other problems like the audio ic boot loop problem etc.
da
Aggiungi la tua risposta
Eduardo Wichoski sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 837
