Salta al contenuto principale
Modello A1419 / EMC 2806 / Fine 2014 o metà 2015. Core i5 da 3,3 o 3,5 GHz o Core i7 da 4,0 GHz (ID iMac15,1); EMC 2834 fine 2015 / Core i5 da 3,3 o 3,5 GHz o Core i7 da 4,0 GHz (iMac17,1) Tutti con display Retina 5K.
570 Domande Visualizza tutte
Hinge on VESA iMac vs Stand iMac (27” 5k Retina)
I've read everything I can find…what I haven't seen is any video or photo…
I really need to see photos of the hinge Apple uses for the VESA mount vs the Stand mount.
I have said iMac completely disassembled trying to figure out installing ANY VESA mount kit…or if someone can point me to somewhere I can purchase the iMac VESA setup for this iMac that has a stand currently?
The iMac was donated so I didn't have option of ordering a VESA mount version.
I have to switch…can't use a mount that goes over the Stand due to space issue.
Thanks
Kriss
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Soluzione Prescelta
It’s a fair amount of work! Here’s the needed parts
  • VESA Mechanism Plate (923-0532)
  • VESA Tongue screws x8 (923-0334)
  • VESA Tongue (923-00084)
  • VESA screws x2 (923-0418)
  • VESA Plate (923-00082)
You need to get behind the logic board to get to the screws
First you need to take the 8 screws out (Light Blue) then the 6 screws holding the hinge (Orange) carefully lift off the hinge. Once the hinge is clear you can then put the VESA Mechanism Plate on reusing the 6 screws.
Then mount the tongue on with the 8 screws
Lastly mount the VESA plate on using the VESA screws
You’ll need to find a friend within an authorized service center willing to order the parts for you.
Punteggio 2
1 Commento:
Thanks! That is what I’ve been trying to sort out...what darn parts I need so I can quit extrapolating what might be able to kludge it. Already torn apart to the needed level...had received faulty information that the hinge was the same for both & that I just needed to deal with the tear down. I’ve torn down a ton of machines considering I’m not an authorized repair person myself. Exist in a community that generally can’t afford the machines they need so I do a LOT of repairs.
da
Dan, does iMac Late 2012 use the same parts as described above?
Thanks
Punteggio 0
1 Commento:
Sadly, the parts are physically different! Apple alters its parts just enough to force the need to stock multiples needlessly.
da
Why do I need the VESA Mechanism Plate (923-0532) its not on the images?
Punteggio 0
9 Commenti:
@Elcheesii 2 - The second image is the plate! Without it you have no means to attach the VESA arm.
da
The "mechanism plate"? Also is there an installation video?
da
@elcheesii2 - The VESA Mechanism Plate is what the VESA Tongue is screwed too from the out side.
da
ok thanks, is there an installation video?
da
@elcheesii2 - This is not the same setup as the 2017 model which you posted in your question.
There is no videos Apple or 3rd party that I know about.
da
Mostra altri 4 commenti
Aggiungi la tua risposta
killerbanshee sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 599
