MacBook 12" 2015(820-00045) no display, no chime, no image
Hello, @arbaman @reecee @refectio and other experts!
Recently I received a dead MacBook 2015 12”. When I connect charger, no chime no image, no backlight.
- I tried measure every power line with multimeter, but I found missing voltage only on PP5V_S0SW_LCD, PP5V1_S4SW and PP1V05_S4SW lines
- I use my ThermoCam and compared the thermo image with good working board but images look the same. So I think there is problem only with image and backlight (maybe)
- I disconnect everything and connected a known good display but does not help
- I preventatively replaced U4700 but no change
On the internet I found, than a lot of people have same issue with this model. Is here any way how to fix?
board number is 820-00045
Questa è una buona domanda?
2 Commenti
Did you press the re-set button on the battery connector?
da Dan
sure man, also tried smc reset, reconnect battery
on the board is not present
EDP_BKLT_EN
EDP_PANEL_PWR
da Tomas
