Salta al contenuto principale
A wireless, more traditional, video game controller produced by Nintendo for the Switch system. Model number: HAC-013.
14 Domande Visualizza tutte
Size for replacement screws
So, my roommate got a small amount of water in my Switch Pro Controller. I’ve opened it up to clean it before, so I didn’t get too mad. I’m usually very careful when doing these types of things, but when I was putting the controller back together after blotting the insides dry, I find that I’m missing a screw! I’ve looked everywhere and I can’t find it. I also don’t know how to figure out the size of the replacement.
The furthest screw to the right is the kind that I need another of. The screwdriver is pointing at where it goes.
It’s about 7mm long, 3mm wide at the head, about 1.5mm at the shaft, and it’s a regular philips head.
Questa è una buona domanda?
Punteggio 0
Commenti:
Hi,
Even though they say Tri-Wing are these any good to you?
da
Unfortunately no. I think the thread on these screws is too fine. I say "I think" because I've previously ordered a set of replacement screws for my joycon controllers (in case this same problem happens with them and in the hopes that one of these would fit into the pro controller) but the thread is too fine for the pro. Also, my current tri-wing driver is stripped, (I'm waiting on a new one to arrive) so I can't even check the actual joycon screws to make sure that these replacements match up with the threading on the original screws for the joycon. I've added a close up picture of the specific screw in question that I need another copy of.
da
So, I've got my replacement Tri-Wing driver tool kit and I compared the joy-con screws to the one that I'm missing and they are definitely a different size than the one I'm missing from the Pro Controller.
da
Aggiungi un commento
Kit di riparazione batterie iPhone
Solo $29.99
Buy Now
Solo $29.99
Buy Now
1 Risposta
Risposta Più Utile
This is a Phillips screw, not a Y screw. Pro and the host screw are completely different.
This is right. http://egamephone.com/index.php?rt=produ...
Punteggio 2
Commenti:
Yes! Holy cow, YES! These look exactly like the screw I'm missing! Thank you! The example picture coincidentally seems to pointing at the exact same slot that my example picture is pointing at. I've scoured the Internet for weeks trying to find these to no avail. (Why didn't I think of using the word "internal" in my searches?) There's not a hardware store near me (that I know of at least) that I could try to ask someone in person for help. I've ordered these screws and will update on if they fit as soon as I get them (which I'm guessing will be a few weeks considering it says it's coming from China). Again, thank you so much!
da
Aggiungi la tua risposta
Lulzigi sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 12
Ultimi 7 Giorni: 36
Ultimi 30 Giorni: 131
Tutti i Tempi: 391
