Salta al contenuto principale
Mattes Display gegen Glossy Display tauschen / Exchange Matte Display
Hi,
kann ich bei einem MacBook Pro aus Mitte 2009 das matte Display-Assembly im Falle eines Defekts gegen ein Glossy Display aus einem MacBook auch aus Mitte 2009 tauschen?
Danke im Voraus für die Antworten!
English version:
Hi,
can I exchange the display-assembly of a MacBook Pro Mid 2009 Matte against a glossy display-assembly of a MacBook Pro Mid 2009 in case of a defect?
Thanks in advance for answers!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Not really, although most parts are just the same, the matte version has the wifi/bluetooth board in the top case and that makes the replacement partially incompatible. If you would be happy without any wireless connection it shouldn’t be a problem instead.
Punteggio 3
2 Commenti:
Thanks for your reply!
Can I install WiFi/Bluetooth on the board or are the Matte and Glossy MacBooks of Mid 2009 are using different internals?
da
@lorenzm It's quite some time since I had the chance to work on a matte 2009 Macbook Pro and I believe I don't have around any spares left to take a look unfortunately. Matte and glossy do have different internals..as I said the Matte has wifi/Bt board in topcase, whereas the glossy has them in the assembly. I honestly couldn't tell if some mod would be possible, I am sorry I can't be of further help.
da
Aggiungi la tua risposta
Lorenz M. sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 31
