It’s very important to always disconnect the battery before disconnecting/reconnecting the screen assembly. The issue is that the LCD connector has pins that have high voltages (i.e. the backlight is ~20V) and ground in very close proximity. When you fumble around trying to line up the connector plug to the receptacle, you can short out the voltage rail and cause damage to the components in the backlight circuit. If you’re lucky, then only a backlight filter is damaged but other times, the entire circuit could be affected. Either way, this type of repair requires micro-soldering and isn’t really a DIY repair.
To test for this, plug your device into a charger or an iTunes enabled computer. Then shine a bright flashlight on the screen. If you can see a dim image, then the backlight circuit has been damaged. If you can’t see an image at all, then it may be the LCD circuit that is damaged.
You can connect the original, cracked screen to confirm this. If the original screen has the backlight on, then the replacement screen has an issue. If the original screen also doesn't show the backlight, then the backlight circuit is blown.
If iTunes doesn’t recognized the device than the problem is more than just a screen or backlight issue.
Votato
Annulla
Punteggio
5
If your cell phone is malfunctioning or has sustained damage, then you need to turn to a reputable
repairman. By selecting the best candidate, you can have your phone up and running in no time.
Below are key traits you should consider during the selection process.
Affordable rates make all the difference. You can save a lot of money when you repair your phone
instead of buying a new one. Competitive pricing allows you to stay within your budget.Superb service for repairing a crack to my iPhone screen.
Not the case at itouch repair .
da android repair arlington
