Salta al contenuto principale
Repair and disassembly guides and support for the Digital SLR line of cameras by Canon, including the Eos series first introduced in 1987.
759 Domande Visualizza tutte
My Canon EOS-1Ds Mark II won't turn on
I haven’t used my Canon EOS-1Ds Mark II for about 6 months. It was working perfectly before I put it away.
I put in a battery in the camera, it cannot be turned on.
It has different behaviors when I try to turn the camera on with different batteries.
  • Old Canon original battery (measured 12.6V) - the top screen flashing an empty battery.
  • Relatively new 3rd party battery (measured 13.4V) - nothing happened.
  • Canon DC Coupler with Adapter (measured 13.4V) - nothing happened.
Any ideas?
Thanks!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Pull out the battery unit and on the top wall of the chamber is a small CR2025 battery which holds your settings. I would replace it.
Depending on how often you’ve recharged the battery packs they be worn out. What does the charging dock unit tell you the batteries condition?
Punteggio 1
1 Commento:
Thanks Dan,
I try with a new CR2025 battery but still do not work.
I know the condition of my NP-E3 battery is not good but the Canon DC Coupler with Adapter should be in a good working order.
The odd thing is that using a lower voltage battery (12.6V) the camera showed an empty battery, using a higher voltage battery (13.4V) or DC Coupler with Adapter (13.4V) the camera showed nothing.
da
How did you fix this? My camera has the same problem.
Punteggio 0
Aggiungi la tua risposta
Hsu sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 11
Tutti i Tempi: 962
