Salta al contenuto principale
Repair and support for the controllers that shipped with the PS3. Released in November 2007 (Japan only) and 2008 (other countries), the six-axis lithium battery powered controller (CECHZC2) is straightforward to repair.
20 Domande Visualizza tutte
Can't get the vibrators out
So my remote had the entire left handle sheared off,
but it still works so im gonna try to fix the damage, but i cant seem to get the vibrators out as the guides appear to have different models (if that's even a thing idk) and so im kinda stick. Appeceriate help.if possible
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
First thing I usually check when I am experiencing difficulties with any repair is how the part looks to be secured. Check if it looks like there is adhesive or if there is small screws. Obviously both would prevent you from removing the vibrators. I will assume there are no screws because it should be obvious is there is. Again assuming it is adhesive the easiest way to soften/weaken the adhesive is using isopropyl alcohol. This should break down the glue enough to allow you to carefully pry the vibrators out. You can use a spudger if you have one, if not a small flat head screwdriver and make sure not to pry on any points that could break off (like in between the body and rotating weight) but rather somewhere like the main body (the larger, metal section) of the vibrator. Hope that helps!
Punteggio 0
Aggiungi la tua risposta
TaloNNn sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 182
