Salta al contenuto principale
Nel giugno 2017 Apple ha aggiornato il MacBook Air 13" con un nuovo processore Broadwell Intel Core i5, che ha permesso di aumentare leggermente le prestazioni e la durata della batteria.
419 Domande Visualizza tutte
Dead after 6 months... Culprit is I/O Board Cable?
I’ve had this 2017 13 inch macbook air for six months, and now its dead... sort of. One day after it stopped turning on I went through the usual procedure. SMC reset did work according to the magsafe light but the laptop still wouldn’t boot. After trying lots of things inside the machine, I found that if I unplugged the battery and the cable that runs from the top of the I/O Board to the MLB, the machine would boot just fine. I would plug the cable and the battery back in as soon as the fan started spinning. It worked fine for a week or so, then the same thing occurred. Did the same fix and the machine worked for another week. There has been no damage whatsoever to this machine. Any ideas why this is happening?
UPDATE
Screenshots from Coconut Battery here.
Questa è una buona domanda?
Punteggio 0
3 Commenti
I would start off checking the battery to see how the charging logic is doing. Install CoconutBattery. Take a snapshot with the MagSafe charger connected and a second one disconnected. Paste both here for us to see Aggiungere immagini ad una domanda
da
Just added screenshots.
da
mmm ... I see zero watts in both. Lets run the battery down a bit ~15 % and test again.
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
I’m suspecting the I/O board is the issue. The MagSafe connector cable to the main logic board is likely damaged. Sostituzione scheda I/O su un MacBook Air 13" di inizio 2015.
Punteggio 1
1 Commento:
Have tried three known good I/O boards and cables already on this unit. Same issue persists.
da
Aggiungi la tua risposta
William Emanuel sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 107
