Salta al contenuto principale
Smart fitness tracker by Xiaomi.
7 Domande Visualizza tutte
I Can t charge my device
My device is amazfit pace 2 and i cant charge it
Questa è una buona domanda?
Punteggio 0
Commenti:
Please elaborate your issue, why you are unable to charge it. Do you have the charger for this device.
da
Yes but i tried with other chargers and original but i cant charge the device
da
Yes, Also I have this issue. How to charge it
da
I have already gave the solution. Please check for dirt accumulation on the connector point of Fitness Tracker & charger. Try cleaning it with rubbing alcohol & pointed tooth-stick (please don’t use any metal object). Once cleaning is done try charging your device; hope this should solve the issue.
da
Aggiungi un commento
1 Risposta
There are two contact points on MI band and the charger, clean these points with some alcohol (hand sanitizer), use earbud or small cotton ball. Please let me know if this fixes your issue.
Punteggio 0
Aggiungi la tua risposta
Pietro Berton sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 205
