My Lenovo N23 Won't Turn On
What should I do when my Lenovo N23 won’t turn on? When you plug it in the little red light comes on like its charging. Then nothing happens when you push the power button.
Veroica L Jackson
Questa è una buona domanda?
As stated on the Lenovo Website: Portable yet rugged, the 11.6" Lenovo N23 Chromebook is the perfect resource for teachers and students. Built to withstand the daily wear and tear of classroom life, it also has the speed, simplicity, and security of the Chrome OS. This small wonder gets up and working in eight seconds—less time than most students are!
Veroica L Jackson
Here is the owners manual for your device: http://cc.cnetcontent.com/inlinecontent/...
You say that a little red light comes on like its charging, however, a solid amber light indicates that the charger is disconnected, and that the battery has a charge between 5% and 20%.
I would recommend using a multi-meter to test your charger.
As for it not powering on, you should try to remove the RTC battery, the main battery and the charger and hold the power button for about 30 seconds. After reconnecting you can see if it will power on.
If that doesn’t work, you will need to test the power-button and the motherboard with a multi-meter, it could be that the power button broke, or that the board isn’t getting power.
Commenti:
Even when the light is green indicating fully charged it still does not power on. How do you access the battery?
Ultime 24 Ore: 4
Ultimi 7 Giorni: 31
Ultimi 30 Giorni: 134
Tutti i Tempi: 2,264
