Here is a generalization of my method for soldering in a new flex cable.
THE BATTERY
I always disconnect the + terminal on the battery. Think about it, if you get in their scraping away epoxy, or doing other things, and the logic board is hot, you can cause arching and burn the board up.
1. At the battery, put Kapton tape on any nearby components.
2. Use a dab of flux to remove the epoxy covering the battery contacts. Also use a brush with 92%+ alcohol to remove the flux, and a static-free cloth to dampen up any excess liquid and debris.
3. Cover the neutral and ground with Kapton tape.
4. I set my Weller to about 475, with a chisel tip and clean/tin it.
5. Put a very small drop of flux on the + connector. Use a copper braid and your chisel tip to gently push (toward the battery). You should only be touching the braid for about 2-3 seconds at most, any more and you can lift pads, etc.
6. Once free, stick a piece of Kapton tape under the + battery connector and the + pad on the board.
- Now if you work on the Flex cable and the iron slips (or one of many other things that could cause arching) you don't risk shorting out the logic board.
FLEX CABLE REMOVAL
1. With the bad flex cable still attached. Use flux, alchohol, anti-static wipe to remove any epoxy covering the contacts.
2. Add a very small dab of flux to the contacts, use your chisel and braid pushing away from the board to "suck up" the solder. 2-3 seconds at the most then let it cool. Don't push too hard. You should be able to gently, and I mean gently, lift the cable and let it free itself. If you pull up on the cable too hard, especially with too much heat, you'll defiantly lift a pad and in for a serious headache.
3. Once you have the old cable off, use your braid, flux, alcohol and anti-static wipe to clean the solder pads
SOLDERING THE NEW FLEX CABLE
1. I heat my weller to about 425. And pop on a very fine solder tip, clean, and tin it. I also use 60/40 resin core solder I think it is like .03mm
2. Get your cable lined up and use some Kapton tape (or have someone help) and get your flex cable lined up on top of the solder pads. I use a jewelers loupe to check the alignment.
3. Place the tip of your solder on one side of the flex cables contact then using a very fine solder tip, touch the tip to the other side of metal contact for about 1 second. The heat will suck the solder into the holes. As it does, again, it takes only a second, pull away your excess solder then the iron. The thing to focus on is you want to get "in and out" as fast as you can when you heat the solder. Done right, you will have a perfect shiny bead.
4. Repeat for the last two flex cable contacts.
RE-SOLDER/ATTACH THE BATTERY
At this point you should have no problem removing the kapton tape between the battery + connector and the logic board and soldering it back on. I switch back to the chisel tip for this.
Once everything is complete, I check the iPod. If all is well you can remove all the excess Kapton tape then cut two small strips placing one top of the battery connections and one over the flex cable connections where you have soldered. This will prevent accidental shorts if someone else (or you) repair the device later and accidental let something hit the contacts.
Everyone has their own method, but after killing a few logic boards when I started repairing i*devices I found what works best for me. Your mileage may vary.
Votato
Annulla
Punteggio
2
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
6 Commenti
Well, that didn't go well.
Must have had a newer model with stronger tape and glue from the folks at Apple.
Guess I don't have the right type of soldering iron or didn't take enough off when I removed the old cable. New cable had holes that I thought would line up and allow for a good contact. Once I heated the old cable and removed it, I had 4 masses where the cable should connect. Tried tacking the new cable down and was never able to get the pieces connected. Didn't want to heat too much. Maybe the tip wasn't small enough or just too old, but it tinned just fine.
Any ideas?
Thanks for all your help. No more attempted Touch repairs for me. Apple wins.
da ggahan
Forgot to add that the metal spudger set I ordered is first rate and came in handy to keep the frustration level below the "throw it out the window" level. Thanks.
da ggahan
Asle, I think that your instructions were what I tried to follow, just did not succeed. The "glue" you mention was probably the opaque stuff I saw on the contact points on the logic board. As this was an ill fated attempt from the start, when I replaced the on/off/volume cable, I also managed to break one of the speaker wires. Another place to be very careful as there is no excess slack when you dig it out of the case. Look carefully for all the screws!
I soldered the speaker cable back together and it worked, but was scratchy - I knew it would need to be replaced. Since I was unable to solder the new on/off/volume cable to the logic board, I did tape it down temporarily to see if it worked. It did, that was how I knew the speaker was scratchy. The tape must have moved because I then got a solid white screen. Time to quit.
I contacted digiexpress and sent the unit off for repair. Still waiting on a speaker arrival. Will comment on experience with them once repairs are completed. Thanks to all.
da ggahan
On one Touch 4g I also suddenly got the white screen. I could not understand because it had been working fine. I then noticed that connector was missing one pin. Look at the picture: https://www.dropbox.com/gallery/943721/1...
I am sure taking the connector in and out has ripped one pin although it shouldn't have. I know you can buy a new connector but this kind of soldering is something I am not capable of. So I am not sure what to do with this one. I already bought my friend a new one :-)
Like we both know now you can't be careful enough when lifting up the mid plane. You have to watch the speaker and the sleep/volume cable. On the other side I have repaired many Touch 4gs since this last one with just success. You get the hang of it. But the first lessons can be costly!
Let us know how you progress.
da asle
Thanks for commenting. I am stinging from this attempted repair, but I am also pretty sure that I could do it successfully in the future. I too paid for the repairs for the friend's Touch, so it has been an expensive lesson.
da ggahan
Mostra 1 altro commento
