Trying to find the cause of HDD failure
So I’m attempting to fix my older 20” 2008 base model iMac for my parents to use.
I had it unplugged for a couple years since the hard drive was slowed down to a crawl and we had already replaced the HDD once before after similar problems, and had it resolved by taking the Mac into the local store who ended up just replacing the stock 250GB drive with a newer 1TB one that gave out in less than 2 years.
I also asked them to upgrade my RAM from the 1GB it had to 4GB, and he ended up putting in a single new 2GB stick, and the other is the stock 1GB stick. So I’m running 3GB of RAM and though they are both the same type they aren’t the same pair.
Is this the single reason my Mac has been burning out so quick?
And should I go ahead with the procedure of replacing this faulty 1TB HDD with a 250GB SSD or could it be something else that’s wrong with it besides un-even memory?
As long as I’m buying some iFixit tools and taking it apart, I don’t mind replacing a few other small things that will help it from burning out entirely. I’d really like to keep this Mac alive!
Thanks for reading.
Questa è una buona domanda?
3 Commenti
Your systems specs: iMac 20" 2.0 GHz Core 2 Duo (Al)
da Dan
Some two cents, most hard disk dislike heats....
Since it is is in all in one configuration, chances some heat will still trap inside.
take caution when replacing and clean the dust away on the fan.
perhaps you all need to change the thermal paste too, as it has been there for some time already.
Well, I suggest you to start with SSD first.
Get good SSD brands, like samsung (pro series), micron.
Backup data is important still.
da Augustine
While I agree SSD's are great, I'm hesitant into replacing the drive in this system given its age. When working on older systems you need to think about the cost and the return, you don't want to over do it as you may not get the length of time of usability as you would want given the costs.
da Dan
