Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2687 Domande Visualizza tutte
Can’t answer incoming calls
Have a weird one have an iPhone 6s works great but when a call comes in screen stops working can’t answer and phone will continue to ring until I do a hard reset. I have taken it apart and cleaned it no water damage have replaced the screen install a new battery.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Risposta Più Utile
Fix for iPhone keeps ringing but screen freezes: I know this is an old thread, but maybe it will help someone else. This happened on my Mom‘s iPhone 6. It started after I enabled Announce Calls for “Always” for her (under Settings/Phone). I turned off Announce Calls and the problem was fixed. The feature works on my iPhone 8 so it also could be a software update issue.
Punteggio 2
3 Commenti:
The person that post about the announcing calls. Thank you soooo much my phone as driven me crazy but you helped fix it. I had tried everything. I turned off the announce calls and the phone is working again.
da
Tried this, no luck. Yikes!
da
I tried this, and it worked!!!!
Before the I phone 6 was ringing and I could not answer calls and front screen would freeze. only way out of it was turning phone off then on again .
Also on outgoing calls I could only call out once before locking. would have to turn phone off then on again.
Text messaging worked the whole time
da
I would check and make sure there is not a software update that is missing. Sounds like a software issue. Go to setting ->General->Software Update and See if it shows and update that is needed. Best of luck.
Punteggio 0
Aggiungi la tua risposta
Patrick Dean Willard sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 4,832
