Salta al contenuto principale
Lanciato il 3 marzo 2017, Nintendo Switch è un dispositivo palmare che può essere usato con la TV o in movimento.
702 Domande Visualizza tutte
Nintendo Switch charging port solder repair
Hello, I'm hoping someone can help me with a problem I've got, I've bought a broken switch in the hopes of repairing it and selling it on. I've taken it apart and found the charging port pins aren't connected to the motherboard so it's not taking charge to the battery. It seems to just be the external pins though not the internal ones. So my issue is that the pins don't reach the little spots of solder on the motherboard so I'm wondering if I could put my own solder in and if the pins need to be individually connected to the mother board or if I could put one line of solder in and connect them all to the motherboard? Hoping someone with more experience will know, any help is appreciated and feel free to ask any questions about it. Thanks in advance
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Soluzione Prescelta
You could draw the solder back next what remains of the pads. No you can't just connect the pins to each other as they are for different voltages. So all pins need soldered individually
Punteggio 2
Aggiungi la tua risposta
Kieran sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,039
