Salta al contenuto principale
iPhone con schermo da 4" introdotto nel marzo 2016 con specifiche hardware simili a quelle dell'6s. Disponibile in Argento, Oro, Grigio siderale, Oro rosa con 16 o 64 GB. Modelli A1662 e A1723.
1049 Domande Visualizza tutte
Why is my iPhone SE reboots itself / won't charge?
Hi everyone,
After replacing my Iphone SE IOS 12.1.2 battery, I have the following issue :
  • The phone reboots itself every 5 minutes approx., while using it or not, plugged in or not.
  • The battery is stuck around 13% and won’t load
I’ve tried to :
  • Change the cable and charger, wall charger or USB plugged in my Mac -> same
  • Plug back the old stock battery -> same issue (what?!)
  • Softly brush the charging port to clean it-> same
  • Installed a new battery (so the 3rd one) -> same
  • Hard Reset -> same
  • DFU Restore -> same
Other :
  • The battery state is “Service” in IOS parameters (for the 3 batteries…)
  • Doesn’t seem to have this issue when plugged in my Mac, while in Itunes restore mode (the one with the Itunes logo on the phone screen). NOT 100% SURE.
Do you know what may be the cause(s) of this issue and what may be the solutions ? Maybe we can discard a battery issue as it appears on 3 different batteries.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
There are some tiny components just above the battery connector. It’s not uncommon for them to get fully or partially dislodged during a DIY repair. One of them (highlighted) is critical for communicating the battery charge state to the CPU.
If it is damaged or missing, it will need to be replaced, which requires a micro-soldering repair.
Punteggio 6
1 Commento:
Hi dear, i have the same problem but witn an iphone 11, any help?
da
That’s one very fine answer with an explanation and schema. And guess what : BOOM perfectly nailed it, kudos to you !
As we can see this FL2400 component is missing, probably damaged using the plastic spudger. Now I have to find a micro-soldering repair shop nearby, too bad we are 7000km away ;)
Thanks again ! I really appreciate your help.
Punteggio 2
4 Commenti:
7000Km? Pfft, that's nothing :>). My record to date is receiving something from 12 000 Km away (Zambia)
da
Nice ! Well maybe you'll receive one day something from France :p
da
J'espère bien, ça me ferait plaisir d'aider mes cousins!
da
Hey there did you ever get it fixed? How much did it end up costing you if you remember?
da
Aggiungi la tua risposta
Julien sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 854
