Salta al contenuto principale
Modello A1312 / metà 2011 / Processore Core i5 da 2,7 e 3,1 GHz o Core i7 da 3,4 GHz, ID iMac12,2
708 Domande Visualizza tutte
Can I install 3 SSDs by replacing the optical drive?
Hi,
I already have 2 SSDs in my iMac (iMac Intel 27" EMC 2429, 2011), one is replacing the original HD (with the thermal probe) and the second one is behind the optical drive. Can I remove the optical drive and install a 3rd SSD? Do I need any special parts if this is possible (like the thermal probe) ?
Thank you!
Tom
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
While its theoretically possible I don’t think you’ll gain that much as the Optical drive port is only SATA II (3.0 Gb/s). I would put in a large 2.5” SATA II HDD instead or just leave the optical drive.
Basically, you’ll use the iMac & Mac mini Dual Drive Enclosure following the optical drive swap out iMac Intel 27" EMC 2429 Optical Drive Replacement. Don’t forget you’ll need a drive that runs at SATA II (3.0 Gb/s)
How about just getting a bigger SSD, swapping out your oldest drive with it. Bigger SSD’s are faster!
Immagine iMac & Mac mini Dual Drive Enclosure
Prodotto
$19.99
Punteggio 1
1 Commento:
Thank you Dan for your very fast reply!
I thought the optical bus was also SATA III, but if it’s SATA II, it makes no sense to connect an SSD.
All the best,
Tom
da
Aggiungi la tua risposta
Tom sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 45
