Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2688 Domande Visualizza tutte
Is it possible to get under 100% max cap after a battery replacement?
I replaced the battery of my iPhone 6S. It had 75% max cap. and my question is if it is possible to get under 100% after a battery replacement cause I don’t want to replace it again.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Max capacity will always deplete over time. The aftermarket batteries will drain and deplete faster so make sure to get the battery replaced from a reputable store or buy a good quality battery.
Punteggio 2
check this post [iOS 11.3] Battery Health Beta - No Change after Replacing Battery
Punteggio 0
2 Commenti:
That isn’t what I was looking for but thanks.
da
if you read it all there are some solutios. In your case if the battery you bought is bigger(more mAh) can be the reason. Or if it is not certified apple battery
da
Aggiungi la tua risposta
Ruben sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 59
