Salta al contenuto principale
Processore quad core Intel Core i7 da 2,2 GHz (3,4 GHz con Turbo boost), 2,5 GHz (fino a 3,7 GHz con Turbo boost) o 2,8 GHz (fino a 4,0 GHz con Turbo boost) con 6 MB di cache L3 condivisa.
774 Domande Visualizza tutte
keyboard won't backlit after battery replacement
Hi:
After replacing the damaged battery, the backlit on my keyboard won’t work anymore. I did the ambient sensor test with the camera and unchecked the options for adjustment on the preference menu. Im currently using the latest version of Mojave. The keyboard used to work and I used the video provided by this channel, which was very helpful. Any suggestions what could be going on? I’ll appreciate any tips.
Questa è una buona domanda?
Punteggio 0
7 Commenti
Have you tried SMC reset?
(SMC=System Managment Control)
Here is a link how to reset it: https://support.apple.com/en-us/HT201295.
da
Hmmmm,that's tricky question.
da
Where you get the battery?
da
Unfortunately, I had to get it from e bay, instead of here in fix it because of shipping issues. The postal office won't handle lithium batteries.
da
da
Mostra altri 2 commenti
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Yes I did. Unfortunately, it didn’t work. I also installed the OS from scratch with no success. I feel very disappointed since I just finished removing the cover to double check every connection. And as expected, everything looks good. The webcam works, the keyboard works. So I guess is if the battery is none-genuine apple product, might that be the reason?
Punteggio 0
Risposta Più Utile
It seems I wasn't the one who had this problem. Meh, I gave up trying to make it work properly and just ordered a new device. Thankfully, I found a seller close to my zip code in Phoenix https://worldpostalcode.com/united-state...
Punteggio 1
thank you. I had a closer look and the backlit connector was still unplugged under the logic board. I missed the connector during assembly. I carefully managed to pull it out and there it was. now its working.
Punteggio 0
Aggiungi la tua risposta
Jose L Ramirez sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 811
