Computer turns on but the screen stays black
Can you turn the computer on the screen never pops on but you can hear the fan running
it is a iMac 2009
Questa è una buona domanda?
it is a iMac 2009
It was the pram battery I fixed it yessss
That sounds like your GPU is gone. Let’s try this press and hold the T key go get into Target Disk Mode, Do you see a FireWire icon on your display? If you do then your dedicated GPU has failed.
I found out is was the pram battery easy fix.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 68
2 Commenti
https://www.techradar.com/au/how-to/comp... <--- this might help you :)
da James
Thank you I will try this. It is crazy cause when I power up the iMac it doesn’t chime on at all fans runs on high and stays dark.
da cliftonerhodes
