Salta al contenuto principale
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
117 Domande Visualizza tutte
Ipad Air 2 touch ID not working after screen change
Hi all,
Changed the screen on a ipad air 2, which you need to remove the touch id home button & flex from the old/damaged screen to place on the new, but after doing so the touch id no longer works, I have double checked the connectors, flex etc and see no signs of any damage so not sure what else to check.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
Batterie per PC portatili
Batterie per tutti i migliori marchi di PC, supportate dalla nostra Garanzia di Qualità.
Acquista ora
Acquista ora
2 Risposte
Have you tried it with the original screen to see if it works?
Punteggio 0
Unfortunately the most likely situation with this iPad is that the home button was damaged when it was removed from the original screen, and this cannot be repaired. If it does not work as a home button you can either replace it or use the 5 finger gestures.
iPad Air 2 Home Button and Gasket Assembly
Immagine iPad Air 2 Home Button and Gasket Assembly
Prodotto
$34,99
Punteggio 0
Commenti:
Note, the replacement button will only act as a home button, not touchID
da
Aggiungi la tua risposta
colin sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 63
