Salta al contenuto principale
Prima generazione del Bose SoundLink Mini rilasciata l'1 luglio 2013. Il dispositivo pesa 655 grammi e ha una copertura Bluetooth di 9 metri.
44 Domande Visualizza tutte
My soundlink mini won't charge, the battery indicator is flashing red
when i try to charge my soundlink mini the battery indicator light just flashes red and won’t charge.
Questa è una buona domanda?
Punteggio 11
1 Commento
This fix worked , thanks
da
Aggiungi un commento
4 Risposte
Soluzione Prescelta
hey kevin,
in most of these cases where either the battery no longer with us or the power PCB bust. to find out which it is you will need to open the speaker using guide: Sostituzione Batteria Bose SoundLink Mini
and then using a multimeter to see if the battery can hold charge if the battery is actually dead then you will have to get a new battery. otherwise see if there is anything unusual with the speaker using this guide:
Bose SoundLink Mini Button Switch Circuit Board Replacement
i wish you good luck
-M
Immagine Bose SoundLink Mini Batteria
Guida
Difficoltà:
Facile
5 minutes
Immagine Bose SoundLink Mini Button Switch Circuit Board
Guida
Difficoltà:
Moderato
10 minutes
Punteggio 5
1 Commento:
I discovered after several attempts to charge it via the Multi-function button, I simply replaced the cable with a new cable (was my hubby's shaving cord) and VOILA!! The Bose mini 2 charged without even using the cradle.
100% charged --working fabulous!!!
da
Have you checked the connector port is clean and undamaged/loose?
Also check that the cable/plug is undamaged- not sure if this charger has an indicator light that it is receiving power?
Try a known working charger (the pin connector on these is fairly common).
Punteggio 3
Press and hold down the centre “multifunction” button (the button with 3 dots) for at least 10 seconds, you should see all of the LEDS light up, this resets the speaker.
Mine wouldn’t charge on the cradle or via the cable even tried another charger and cable.
After reset it works normally again.
Punteggio 1
1 Commento:
That's fantastic! I tried multiple cables and used both the cradle and the port and couldn't get any of them to charge it. I held down the multifunction button for 10 seconds when I saw this entry, everything reset and it appears to be charging!
da
I have no “mute” button. My Soundlink Mini speaker works, but I am concerned about flashing red light. I have purchased many Bose products, but I will be hesitant now. This was once a great company.
Punteggio 0
Aggiungi la tua risposta
KEVIN TAYLOR sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 14
Ultimi 7 Giorni: 134
Ultimi 30 Giorni: 651
Tutti i Tempi: 50,288
