Salta al contenuto principale
Modello inizio 2011, A1278 / processore i5 2,3 GHz o i7 2,7 GHz
779 Domande Visualizza tutte
13" MacBook Pro (i5- second generation) 320 GB -HD upgrade
Can the 13" macbook pro hard disk(second generation i5 be upgraded from 320GB to 750 GB?
- From what I understand, the lower end model uses a 5400 prm drive. Can it take a 7299 RPM drive? And if so what is the best Hard drive to use.
Thank you
Manodh
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Your machine uses a standard 2.5" Serial ATA (6 Gb/s) 9.5 mm or 12.5 mm. http://eshop.macsales.com/item/Samsung/H...
Punteggio 3
It's possible to put a HDD up to 5400rpm.
I've put this one and no problem it's working very more rappidly.
This one was a 7200rpm with 500gb 16mo hide
(http://www.macway.com/fr/product/13202/5...)
Punteggio 0
Aggiungi la tua risposta
manodh sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 3,945
