Salta al contenuto principale
L'Apple iPhone 5s è stato presentato il 10 settembre 2013. La riparazione di questo dispositivo è simile a quella dei modelli precedenti e richiede cacciaviti e strumenti di apertura. Disponibile nelle versioni GSM o CDMA con capacità di 16 , 32 o 64 GB nei colori Argento, Oro e Grigio Siderale.
3531 Domande Visualizza tutte
Can't restore after battery replacement (iTunes Error 9)
After battery replacement on my iPhone 5s, it resulted in boot loop and when trying to restore/recover by iTunes, I get the error message “Error 9”.
I’ve tried change USB cables, and even tried the 3d part software “3u Tools” but nothing works.
Any ideas?
Thanks in advice for help!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
There are several things that can cause Error 9 on the iPhone 5S. One that may be of interest here, due to this following a repair attempt, is when the logic board is damaged via '“Long Screw Damage”. LSD occurs when you inadvertently put a long screw where a short screw should go in one of the holes for the LCD bracket. Take a look at Step 17 of this guide to see if the screws you put in place match those from the guide.
If this is the case, the phone can be repaired via a micro-soldering repair but this is not a trivial repair and the cost may outweigh the value of the device.
Punteggio 1
1 Commento:
Thank you very very much! I'll check this out!
da
Did you enter DFU mode? If not, try that. Hold the home + power button simultaneously for 10 seconds to enter DFU mode. That can help.
Punteggio 0
2 Commenti:
Yes, it's when the iTunes icon and a cable is showing up on the display, right?
da
Yep. Exactly.
da
Aggiungi la tua risposta
Miss Galaxee sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 317
