Salta al contenuto principale
Modello A1136 con 30, 60, o 80 GB di hard disk con plastica frontale bianca o nera
779 Domande Visualizza tutte
Lagging iPod 5th Generation
Hey guys,
My iPod 5th Generation lags when I play certain songs. I’ve tried already a lot of possiblities: first deleting only this album, uploading it again, but the same. Then restoring the iPod through iTunes, then I upload again three albums and already at the 5th song starts to lag.
At this point I can feel while holding in my hand that the hard drive is lagging too. I can escape of this only with the two button reset. After that everything is fine again till I get to one song where it starts to lag again.
How could I solve this problem? Do I need to change the hard drive, or there is other possibilities?
Questa è una buona domanda?
Punteggio 0
2 Commenti
which iPod 5 is this? sounds like the original...
da
iPod 5th G. 60gb Serial No : 8K632DWKWEF
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
I think you are correct that it is the HDD, the iPod is several years old and has likely played a fair few tunes in its time. You will need to find a new HDD and follow this guide
iPod 5th Generation (Video) Hard Drive Replacement
read the guide a few times, take your time and it should be fine.
Punteggio 4
1 Commento:
Mine went a few years ago ended up putting in a SSD unit Tarkan iFlash-Dual SD Card Adapter For iPod 5 Generation and Later best upgrade I could have done!
da
Aggiungi la tua risposta
Tamas David sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 13
Tutti i Tempi: 225
