Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1687/A1634. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
1022 Domande Visualizza tutte
Why is my mobile data not working at times?
My iphone 6s plus mobile data sometimes work sometimes doesn’t work properly and i tried different sim provides but the issue is same my wifi is working fine but my mobile data sometimes doesn’t work at all and when it works it speed is very low sometimes when it doesn’t work i have to restart various times then it works please help me guys i have break my head alot into this but can’t do much did everything reset network settings & updated ios reset device did everything then too i am fade up with cellular thing please help me guys i really need your help
Questa è una buona domanda?
Punteggio 0
2 Commenti
Was the phone ever bent or did it suffer bad accidental drops ?
da
Never bro it wasn't bent ever
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
you may like to check your network coverage or outages. Depending on where you are in the world you may just be unlucky enough to be in areas with poor 3g coverage. Ask friends/colleagues if they are having the same problem?
If it is not the sim, not the network coverage then it may be the antenna needs replacing
Sostituzione Antenna Cellulare iPhone 6s
Punteggio 2
1 Commento:
Okay bro i ll go for antenna replacement
da
Questa risposta era destinata originariamente a un'altra domanda.
I got exactly the same issue with a 6s I had been given to repair some time back, but I have to admit that I regrettably had to decline it after some testing…it’s not a typical 6s failure and when a component gives troubles just after a certain amount of time is very hard to diagnose even with proper tools. I hope someone more knowledgeable could give some insight, but consider the time/reward ratio sometimes fights against a component level repair.
Punteggio 2
Mobile data is provided by the mobile operator with whom you have a contract, ask first.
Punteggio 0
Aggiungi la tua risposta
Ahmed Ghosi sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 105
