Salta al contenuto principale
Modello A1502 / processore dual core Intel i7 2,6 GHz (Turbo Boost fino a 3,1 GHz) o 2,8 GHz (Turbo Boost fino a 3,3 GHz) con 4 MB di cache L3 condivisa.
494 Domande Visualizza tutte
Is there any LCD connector adapter to iMac 27in LCD 2010
I have MacBook Pro 13” 2014 with broken screen and iMac 27” 2010 with faulty logic board.
I want to use this iMac 27” 2010 as main display screen with my MacBook Pro
I am looking for an adapter so I can connect the displays connector from MacBook Pro logic board to iMac display cable
If it works, I then plan to put the entire MacBook Pro into iMac 27” chassis to make special iMac 27” with this MacBook Pro logic board
Looking forward for your advice
Thank you
Questa è una buona domanda?
Punteggio 0
2 Commenti:
To clarify, you want to use the connector of the logic board of the MacBook and connect it tho the one from the LCD in the iMac ?
da
yes, I do . I suppose both Macbook and iMAC use LVDS , but their connectors are different, so how can I do that, is there available LVDS adapter for them ? and does it possible ?
Thanks
da
Aggiungi un commento
1 Risposta
Your going to need schematics, alot of time, and knowledge of soldering. You probably going to have to make your own connection. Use the lcd connector from the broken screen separate all the wires and using schematics figure out where everything goes.
Punteggio 0
Aggiungi la tua risposta
Tony Bris sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 95
