Salta al contenuto principale
Repair information for the 4th generation iPad. Released November 2, 2012. Model numbers: A1458, A1459, and A1460.
408 Domande Visualizza tutte
Charging port not working
I have an ipad A1567 and can not find any info on it. The fire port needs replaced. How can I find it?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Another option is to have the charge port replaced by a repair shop that does micro-soldering repairs. It should be less expensive than replacing the board.
Punteggio 2
From a quick search I found that your device has its charging port soldered to the motherboard. Just look in the store for the logic board of your device instead.
Punteggio 0
yes but i do not see that ifixit sells this part :(
Punteggio 0
2 Commenti:
Yes but i do not see that ifixit sells it :(
da
This is the part you are probably looking for. iPad 4 Lightning Connector MAKE SURE IT IS RIGHT FOR YOUR MODEL. It should be an iPad 4th Gen Retina A1458, A1459, or A1460
da
Aggiungi la tua risposta
Stephen Brackenrich sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 123
