Do all Playstations use the same optical drive?
do all the play stations use the same optical drives?
Questa è una buona domanda?
no there is a BDP-010 and a BDP-015 and a BDP-020 and a BDP-025 from what i have seen the BDP-010 uses a 2 laser system and the other 2 use 1 laser. they say that the 020 and 025 are interchangeable but you will still have to change you circuit board from your old drive to the new drive because there is a chip on it that has a key that matches a key on a chip on the motherboard and if they are not the same the drive will not be able to play games.
thanks for the info I was getting ready to order a broken PS4 for $50 so i just had to make sure. I worked on consoles before but mainly Xbox's
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 427
