putting the glass back on
how do i get the glass to stay on after replacing the digitizer?
Questa è una buona domanda?
Hi bryant,
After pluging the digitizers cable in and wiping the lcd and inside of the digitizer, just place it down gently ontop and as long as all the clips are not bent then just slowly apply even pressure down upod the edges, keep doing this working your way along the edges and eventually you will start to here clicks, this is good. If however you apply to much pressure in one place and click that side in there is a chance that the screen will crack again (this happend to me). so nice even pressure. :)
hope this helps.
Mic
Did it work well for you?
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,012
