How much does it cost to have the screen replaced?
I was wondering what Apple charged for replacing the display for a 15” mid-2014 Macbook Pro? It is out of warranty and very badly scratched!
Thanks,
Update (11/22/2018)
I’ve added a photo, which actually makes it look worse than it is for everyday use. For the most part, I forget the scratches are there whilst I’m using my MacBook, but every now and again it annoys me.
As to how it happened? I’m not entirely sure! I think it' has been over time due to poor cleaning attempt and potentially my cat!!
I'm not comfortable that I could follow those instructions successfully myself. It’d be great to find a private repairer instead of Apple. I am in Australia.
Questa è una buona domanda?
6 Commenti
Lets see if @pollytintop can help you. She's located In Batemans Bay, south of Sydney.
da Dan
Thanks! I should've said, I am in Brisbane too.
da Ross Hopkins
$500 for just the screen... not cheap. Maybe look at a screen protector that may smooth out the appearance a bit? Am not local to Brissy so no recommendations, good luck.
da pollytintop
@pollytintop Maybe try a glazed surface screen protector, if it can be found..I tried the glass kind used in iPads but it doesn't make much difference.
da arbaman
I'm not sure if this helps Apple did offer an extended warranty on damaged anti-reflective coating failure which is really your issue here. Apple Extends Free Repairs of Anti-Reflective Coating on Select MacBook and MacBook Pro Models. Its worth the trip to the Apple Store or authorized service center to see if you can convince them you didn't know of the program as you were in the outback ;-}
da Dan
Mostra 1 altro commento
