Salta al contenuto principale
L'aggiornamento di Marzo 2015 della linea 13" dei Macbook Pro con Retina Display (modello A1502) adotta processori Intel Core i5 ed i7 di quinta generazione, introduce inoltre il trackpad Force Touch.
1185 Domande Visualizza tutte
MacBook fan not turning on
I have MacBook Pro, the fan doesn’t turn on by itself but can be turned on manually with Macs fan control application.
I have tried smc and pram reset, I can’t reinstall new Mac OS due to overheating and switching it self off.
I have also used the apple diagnostics and when the fan is tested it works fine.
any ideas what it could be.
thank you.
Update (11/21/2018)
here a picture of the temperatures
Questa è una buona domanda?
Punteggio 1
2 Commenti
You'll need to get something that can better monitor your systems thermal sensors and fans. I would recommend getting this app: TG Pro. Once you get it running take a snapshot and paste it here for us to see. Aggiungere immagini ad una domanda
da
Let's first identify your exact machine so we are all on the same page. Go under the Apple to "About this Mac" and tell us your correct machine.
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
Here’s the needed steps to replace your fan: Sostituzione ventola MacBook Pro Retina 13" inizio 2015 and here’s the needed part MacBook Pro 13" Retina (Late 2013-Early 2015) Fan
Immagine MacBook Pro 13" Retina (Late 2013-Early 2015) Fan
Prodotto
$19.99
Punteggio 2
Which fan is inoperable? The left fan or the right fan? Are both fans inoperable?
If you can’t control the fans with fan control software nor does a SMC or PRAM reset help, I think the fan(s) are dead.
Sostituzione ventola destra del MacBook Pro 15" Retina Display versione metà 2015
MacBook Pro 15" Retina (Late 2013-Mid 2015) Right Fan
Sostituzione ventola sinistra del MacBook Pro 15" Retina Display versione metà 2015
MacBook Pro 15" Retina (Late 2013-Mid 2015) Left Fan
Immagine MacBook Pro 15" Retina (Late 2013-Mid 2015) Left Fan
Prodotto
$39.99
Immagine MacBook Pro 15" Retina (Late 2013-Mid 2015) Right Fan
Prodotto
$39.99
Immagine MacBook Pro 15" Retina Display Mid 2015 Ventola sinistra
Guida
Difficoltà:
Moderato
15 - 40 minutes
Immagine MacBook Pro 15" Retina Display Mid 2015 Ventola destra
Guida
Difficoltà:
Moderato
40 minutes - 1 hour
Punteggio 0
3 Commenti:
It only has one fan as it’s a 13inch, fan works fine when manually enabled with smc or any other fan application.
da
@justanotheruser You picked out the wrong device! You have it listed as a 15" which has 2 fans instead of the 13" which has one fan...
da
Thats why I had recommended using TG Pro so we would have a better view on the fans. Even with just one fan (if this is a 13" model) you really need to see the tachometer values which your current fan control app doesn't show.
If you want to shotgun this then just replace the fan.
Frankly, I would do deeper diagnostics first, as you may have a bad connector or the line to the SMC maybe damaged somehow.
da
Aggiungi la tua risposta
momomomo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 7
Tutti i Tempi: 7,096
