Salta al contenuto principale
Informazioni sulla riparazione e guide per l'iPhone 8, lanciato il 22 settembre 2017. Modelli A1863, A1905.
873 Domande Visualizza tutte
iPhone 8 NFC isn't working after frame replacement
I was given an iPhone 8 to repair that was smashed on the front and the back, as well as having the frame bent. Long story short, I transferred the parts into an aftermarket frame (with glass and wireless charging coil pre-installed) and installed a new screen. Everything is working brilliantly (iOS 12.1) until today when I tried using Apple Pay to make a purchase. I had gone through the setup with my bank card and it shows in the Wallet, but doesn’t come up when I hold my phone up to the reader.
I just opened it up again and disconnected the battery and reseated the connector for the charging coil. I’m going to try again at a different shop but I was wondering if anyone has experienced this? Could it just be a faulty NFC antenna in the coil?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Turns out it was a faulty NFC/Wireless Charging coil. The flex ribbon that extends from the coil and connects to the logic board actually came off the coil. Looks like the solder points for the pads was pretty weak.
Punteggio 0
Risposta Più Utile
It’s possible you have a defective housing…most of the antennas are directly embedded in the housing. In previous iPhones, there was obvious NFC coil but there was a tiny flex that had to be properly connected at the top left hand corner of the logic board. The iPhone 8 does away with this but generally speaking, antenna issues are usually related to either a bad or damaged housing or a screw done wrong in the antenna areas. The large coil, while called an NFC coil is almost certainly not for NFC transactions but for charging.
Punteggio 2
1 Commento:
From what I've seen in the teardowns, the NFC chip itself is on the top right hand corner of the board, but the antenna is with the charging coil. I'm still trying to research it, but I'm going to assume that the connector that comes from the charging coil to the board is for charging the battery, and that the NFC connector is simply a contact on the bottom side of the board to two brass contacts that are exposed on the base of the NFC/Charging coil flex connector.
da
Try again at a different store. It could have been a problem on their end, not your end.
Punteggio 1
2 Commenti:
I just did. Same issue. I double tapped the home button and it manually brought up the wallet app telling me to hold it near the NFC reader. Nothing. Tried it with my LG G5 and it worked.
da
Ah, sounds like you have a bad NFC coil then. Try a new one and see if it works out with a new one.
da
Aggiungi la tua risposta
Bill Shannon sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 31
Tutti i Tempi: 5,913
