Salta al contenuto principale
iPhone con schermo da 4" introdotto nel marzo 2016 con specifiche hardware simili a quelle dell'6s. Disponibile in Argento, Oro, Grigio siderale, Oro rosa con 16 o 64 GB. Modelli A1662 e A1723.
1049 Domande Visualizza tutte
Domanda Chiusa
Is normal what happened to my iPhone?
I would know if is normal with happened with my iPhone SE. After a bad charging in the car, motherboard doesn’t work anymore, and ok, also I readed that motherboard gets a damage after charging in the car without original Apple charger adapter. But this situation seems more serious because I noticed that also display doesn’t work. I put same display in another iPhone SE that 100% works and this display doesn’t work. So, in this case, why also display got a damage?
Thank you an advance for reply.
Questa è una buona domanda?
Punteggio 0
2 Commenti
Are you sure it’s the logic board? What’s the possibility that it is just the screen that’s broken?
da
I tested also logic board in the 100% iPhone SE working with his display and I can confirm that also logic board doesn't work. On this iPhone I put also that display and I noticed that also display doesn't work. But this situation seems serious, because I readed that after charging in the car only motherboard gets a damage, not also display. So, why also display doesn't work?
da
Aggiungi un commento
2 Risposte
Risposta Più Utile
This is 95% chance that Tristar ic is damaged.
This will cause the device not to charge/boot as well s have no display
You will.need board level work.
Punteggio 1
3 Commenti:
Isn't so, because I tried also in another iPhone SE that 100% works and I noticed that display doesn't work and this display is from iPhone SE that has also motherboard broke. So, charging in the car caused a damage to my motherboard and also to my display, because this display doesn't work also on a working iPhone SE (and I'm sure, because the display of that iPhone SE works perfectly). So, why charging in the car caused damages also to display and not only to motherboard? Is normal that also display got a damage?
da
I have seen the whole board get burnt out from bad charges so the possibility that the screen has received voltage to it is possible.
da
Ok, and in this case repair motherboard is more hard? Because I readed "if also display burnt out, motherboard got a damage more serious" and this guy said "in this case repair motherboard is more hard or impossible". This is true?
da
There is a good chace you may need a board repair, after testing with known-good screen the only variables are the battery, charge port and logic board components. if replacing the battery and charge port don’t work. it will definitely be a board issue.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 56
