Salta al contenuto principale
D-Link DCS-825L is a HD Wi-Fi Baby Camera.
What should I do if my WiFi is not connecting to the camera?
I can’t get my WiFi to connect to the baby camera, what should I do?
Questa è una buona domanda?
Punteggio 0
1 Commento:
student question
da
Aggiungi un commento
1 Risposta
Not Connected to Specific Wi-Fi Network
Make sure that your phone/device is connected to the Wi-Fi Network that is specific to your Wi-Fi Baby Camera (called “myBabyCam-xxxx”). The “xxxx” part of the Wi-Fi will be specific to every individual Wi-Fi Baby Camera and is located on the label on the back of the Wi-Fi Baby Camera as well as on the back of the quick installation guide.
You have the Wi-Fi turned off on your phone
Go to your phone/device’s settings, select Wi-Fi and check to see if your Wi-Fi is on. If not, switch the Wi-Fi on.
The Baby Camera is not turned on.
First, check that the Wi-Fi Baby Camera is plugged into an electrical outlet. If it is, press the power button located on the front, upper right side of the Wi-Fi Baby Camera.
Punteggio 0
Aggiungi la tua risposta
Alexis Clopton sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 284
