es1 civic power steering does not work
Power steering in ES1 is not working. What can be the cause
Questa è una buona domanda?
Hi @malco1 ,
Check the level of the power steering fluid to make sure that it is correct.
Check that the power steering drive belt is OK and has the correct tension etc.
Here a two images taken from the 2002 Honda Civic owner’s manual that may be of some help. (you didn’t state the year model of your vehicle but it should be the same as it is within the range that you selected)
(click on images to enlarge for better viewing)
If they are both OK it may be the power steering pump that is the problem.
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 546
