Salta al contenuto principale
Apple Logo shows for 5 seconds then shuts off after digitizer change
I changed the display, home button, and rear camera on an iPad 5 and now when I turn it on, the Apple logo comes on for 5 seconds then goes away and only the backlight stays on.
I have taken the device back apart several times to make sure that all the connections are clean and properly plugged in, but it still acts like this.
What am I missing or where do I go from here?
Everything worked good on it when it was brought to me, minus the digitizer being broken..
Thank you.
Questa è una buona domanda?
Punteggio 0
2 Commenti:
What happens when you use the original digitizer?
da
That is not an option since the original is in about 1,000 pieces.
da
Aggiungi un commento
1 Risposta
I suspect you have received a faulty or low quality digitizer. I would try another digitizer just to be 110% sure. If a new digitizer doesn’t fix anything; I suspect it’s a Logic Board issue.
iPad 5 Screen Digitizer
iPad 5 LTE Front Panel Assembly Replacement
Immagine Replace a screen compatible with iPad 5 A1822 A1823 and iPad Air (1st Gen) A1474 and A1475. Includes all of the small parts preinstalled in the assembly. Part #821-4894-A.
Prodotto
$44.99
Punteggio 0
1 Commento:
I will throw a different digitizer on tonight when I get off work.
Thank you.
da
Aggiungi la tua risposta
sunruh sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 93
